Jetmans
www.alsspecialtymarine.com/new_vehicle_d...sc=Outboard%20Motors
www.boatsplus.com.au/mercury-outboards/m...boards/prod_403.html
T'es sur qu'il est pro ton pro???
Chez moi 'Water-cooled w/thermostat', ca veut dire refroidissement a eau avec thermostat !!!!
Sinon du manuel moteur:
Flushing The Cooling System
Flush the internal water passages of the outboard with fresh water after each use in salt, polluted, or muddy water. This will help prevent a buildup of deposits from clogging the internal water passages.
IMPORTANT: The engine must be run during flushing in order to open the
thermostat and circulate water through the water passages.
A moins que ton moteur ne soit pas un Mercury 50cv EFI de 2007
Je vais reverifier, mais la cause semble entendue...
